Latest post Wed, Sep 26 2012 12:13 AM by Dom Q. Silverio. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Mon, Sep 24 2012 10:45 PM
    • Gasper552
    • Joined on Mon, Oct 24 2011
    • Los Angeles
    • Posts 32
    • Points 380
    Avid 6.0.3 GO PRO AMA Transcoding Slowly
    Quick question. Are any of you getting faster than realtime when transcoding Go Pro media, or any quicktime based media for that matter?
    AVID Symphony 6.0.3.2, MAC PRO OS X Lion 10.7.4, Processor: 2 x 3 GHz Quad-Core Intel Xeon, Memory: 8 GB 800 MHz DDR2 FB-DIMM, Graphics: NVIDIA... [view my complete system specs]
    Filed under: , , , ,
  • Mon, Sep 24 2012 11:58 PM In reply to
    Re: Avid 6.0.3 GO PRO AMA Transcoding Slowly
    I can't get it to see it via AMA. I don't think there's an AMA plugin for Go Pro.  I do a straight import to DNxHD 175X (thus, I need to transcode) and it took 50 seconds for a 43 second clip.  So no, on my end it isn't faster than real time.
  • Tue, Sep 25 2012 12:25 AM In reply to
    What are your specs?
    I get faster than real time with my specs below for DSLR H.264. It takes about 45 sec for 1 min clip (DNX 175).
  • Tue, Sep 25 2012 12:45 AM In reply to
    2.3 Ghz i7...MacBook Pro 2012.  16GB RAM.
    MP4 and H.264 are different.  I get faster speeds with my DSLR too.
  • Tue, Sep 25 2012 12:56 AM In reply to
    Shane Ross:
    Yes and no. MP4 is a container, just like QT. H.264 is a encoding profile that can be in MP4 file format.
    Both DSLR and GoPro uses H.264 as the encoding format. Canon DSLR uses QT as its container while GoPro uses MP4.
    If you have a test file (10 sec or more), I can give you numbers with my system. Laptops in general will be slower with the desktop CPU counterparts (assuming chipset/CPU are relatively close in digital age).
    • Gasper552
    • Los Angeles
    • Posts 32
    • Points 380
    Dom Q. Silverio:
    You are still on Avid 5.5, which is solid when file importing. In Avid 6 that is not the case, even when transcoding via AMA it's realtime at best.
  • Tue, Sep 25 2012 12:59 AM In reply to
    Gasper552:
    That is just the profile I have not updated. I have 6.03 as my main and 6.5 in my "test drive OS drive".
  • Tue, Sep 25 2012 1:02 AM In reply to
    Well, they must be compressed differently, or something. I get better, faster import times with my Canon DSLR than I do with my GoPro
  • Tue, Sep 25 2012 1:12 AM In reply to
    Shane Ross:
    Do you have any applications or utilities installed like Perian?
  • Tue, Sep 25 2012 1:14 AM In reply to
    • Gasper552
    • Los Angeles
    • Posts 32
    • Points 380
    Dom Q. Silverio:
    Gasper552:
    Oh ok, thats actually good to hear. Now my question is what I am doing wrong. My workflow is as follows:
    I bring GO PRO Files into a program called QT Change to give the files Timecode.
    Then, I link to those files via AMA. The files are located on a Shared Storage Drive over Fiber, and I then transcode to 15:s.
    If the file is 1hr in length, it will take 1 hr to transcode. What do you think is happening?
  • Tue, Sep 25 2012 1:35 AM In reply to
    • Merlin2004
    • Sydney, Australia
    • Posts 149
    • Points 1,835
    Gasper552:
    That's interesting. I thought QT Change only worked on Quicktime files. Or is GoPro now producing something other than .MP4s?
    Also I think the H264 implentation in Gopro files is slightly non-standard...
    Freelance. Whatever turns up! [view my complete system specs]
  • Tue, Sep 25 2012 1:40 AM In reply to
    MP4s have the QT icon on my computer...so they open in QT by default.
    And no Perian on this machine.
  • Tue, Sep 25 2012 1:57 AM In reply to
    If someone can upload a 10 secs or more clip I can test.
  • Tue, Sep 25 2012 2:11 AM In reply to
    • Merlin2004
    • Sydney, Australia
    • Posts 149
    • Points 1,835
    Shane Ross:
    Shane, "QT Change" is a utility written by Video Toolshed. http://www.videotoolshed.com/products
    it has nothing to do with the Quicktime Player. it works by modifying the header of a QT file.
    • Gasper552
    • Los Angeles
    • Posts 32
    • Points 380
    Merlin2004:
    Gasper552:
    All you have to do is change the file extention to .MOV and then in the "Reset or Alter" Colum select Flatten Afterwards. Then it should work.
