The new transport controller in v11 can work even better for you if you learn how to augment factory configuration and create your own task centered presets.
A tip not included in the tutorial: although DS does not use the Eucon utility for configuration, you can label your presets inside the utility or even create visual icons which will show on the device display when you press the "eye" key.
At some point I may share my transport presets. Visit www.hdhead.com to check if they are available. I am not sure why the video is cropped the way it is, but if you right clck on it you can select "watch on Vimeo" instead.
Igor Ridanovic
www.HDhead.com
Thanks Igor, again a real nice tutorial.
http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
