Latest post Thu, Sep 6 2012 9:26 PM by Marianna. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Sep 6 2012 8:46 AM
    Make Alpha Effect
    Hi all,
    Is there any way within Avid FX to draw a custom shape to create an alpha like you can with the BCC make alpha? All I can find is set shapes like circles and rectangles etc.
    When I try to draw a spline I can't seem to work out how to use that as a key.
    Craig.
  • Thu, Sep 6 2012 10:02 AM In reply to
    • Posts 10,215
    • Points 218,190
    Re: Make Alpha Effect
    craig r harbour:
    Is this something like you are looking for, Craig?
    http://www.screencast.com/t/l0pJU6Ontk
    I animated it to show further possibilities
    Regards,
    Douglas
  • Thu, Sep 6 2012 3:04 PM In reply to
    Hi Douglas,
    Not really what I'm after. I want an alternative to animatte but with the advantage of being able to move the newly created matte around the screen. BCC Make alpha does this which is fine if I have access to it but being a freelance editor you never know if the next suite you end up in is going to have BCC installed now that it has been removed from version 6, I can however be sure that Avid FX will be there.
    The way I would do it With BCC Make Alpha is Make Alpha from Alpha, turn on pixel chooser and in PC region change shape to custom and then draw the shape I need.
    If I try to do something similar inside Avid FX I can only go as far as getting custom shapes like circles and rectangles.
    Hope that all makes sense.
    Thanks in advance.
    Craig.
  • Thu, Sep 6 2012 5:08 PM In reply to
    craig r harbour:
    There is a way, and that way involves using the "Mask" tracks present on shapes in AvidFX. I just did a screencap with voiceoever showing what I mean here ;
    http://www.borisfxresources.com/AvidForum/AvidFXmasks/AvidFXmasks.html
    —————— Dirk de Jong BorisFX
  • Thu, Sep 6 2012 5:50 PM In reply to
    Yup this is what I wanted to do, Thanks.
    It will take a a bit of practice though to get my head a round it!
    Thanks again,
    Craig.
  • Thu, Sep 6 2012 9:26 PM In reply to
    • Posts 10,215
    • Points 218,190
    craig r harbour:
    Hi Douglas,
    Geeked Yes it was, Craig.
    While I was asleep in Japan, Dirk did that useful quick tutorial (below) which actually describes the exact method I used in my demo above.
    Thanks for filling in the gaps, Dirk. Yes
    Regards,
    Douglas
    PS. I cover quite a lot about using the spline tracks/spline objects etc. in some the tutorials on my site.
    Feel free to take a look.
