Latest post Wed, Aug 22 2012 9:40 AM by Editosaurus. 2 replies.
  • Wed, Aug 22 2012 8:10 AM
    • Editosaurus
    • Joined on Sat, Feb 11 2012
    • Auckland, New Zealand
    • Posts 54
    • Points 615
    Is there a best level to have your 24 bit audio when converting to 16bit
    Does anyone know if it's necessary to limit the peaks of a 24 bit audio file before converting to 16bit. I know the dynamic range is reduced, I just want to make sure nothing is clipped.
    2014 MacPro, 6 Core 3.5GHz Intel Xeon E5, 64Gb RAM. Dual AMD FirePro D700 Graphics. OSX 10.10.3 Avid MC 7.0.4.3 [view my complete system specs]
  • Wed, Aug 22 2012 8:41 AM In reply to
    Re: Is there a best level to have your 24 bit audio when converting to 16bit
    The only difference between 24bit 20 bit and 16 bit is quantisation resolution. Levels or dynamic range aren't altered.
    The lower bits that produce the finer qunatisation levels are just ignored and unless you aquired or produced the sounds in 24bit audio that detail isn't there anyway most likely!
  • Wed, Aug 22 2012 9:40 AM In reply to
    • Editosaurus
    • Posts 54
    • Points 615
    Great, thanks. It was recorded and mixed at 24bit. Just wanted to make sure I don't make a foolish mistake after going to that trouble.
    Cheers,
    James
