Hey,
I'm curious to know if there is an effective way of slowing down and stretching audio without mixing down my audio at all?
I have a clip shot at 100fps w/a 24fps TC and audio recorded with a 24fps TC too,
I want to slow down the audio and stretch it to fit the duration of my 100fps shot.
I understand I could cut the audio into a sequence, add filler, mix it down, then apply the TImeshift effect and stretch the audio to fit that way, but its so long winded and I dont want to be dealing with mixdowns.
Any alternative suggestions?
Many Thanks
If you open up the audio suite tool there's a filter that will do that. I forget what it is called though.
In the AudioSuite Window, you have Time Compression Expansion and Time Shift.
Time Compression Expansion : Set the Ratio to 4.1667 (I think)
Time Shift : Set the Pitch shift to (probably) 24%
Sylvain Primeau
Self-employed worker - Les productions Primeau Medias
primeaumedias.com
Radio-Canada/CBC news editor
cbc.ca / ici.radio-canada.ca
