Latest post Thu, Jun 14 2012 11:19 AM by mjolnarn. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Jun 13 2012 8:39 AM
    • Ian Nicholson
    • Joined on Mon, Aug 9 2010
    • Sydney, Australia
    • Posts 65
    • Points 965
    Importing REELS from Liquid into MC 5.5
    Hi All,
    Sincere apologies if this topic has been going around and around, but I cannot seem to find a direct answer to something that should be relatively straightforward.
    I used to use Pinnacle Liquid 6.1, and I have an unfinished project that I'd like to bring into MC.5.5 to finish.
    I AM a Media Composer noob. In Liquid, however, I am crash-HOT, but due to the problems of MC and Liquid co-existing on the same machine, I have uninstalled Liquid.
    The project was imported into Liquid from a HDV camera, and is in 1080p/25. In my Liquid REELS folder, the reels exist by their name and a large .M2V file (11GB) and 2 .WAV files of about 350MB each (presumably left and right channels). There are some other files in addition, which may, for all I know, contain data regarding scene changes etc..
    What is the best way for me to load this files into MC 5.5 for editing, syncing audio, detecting scene changes, etc..?
    Thanks in advance!
    MC 8.5.0 on Intel i7 3770K 3.8GHz, Gigabyte GA-Z77X-D3H, nVidia GTX670 2GB, 16GB RAM, 2 x 128GB SSD, 13TB disk, 2 x HP 2711x 27" LED monitors, Windows... [view my complete system specs]
    Filed under: , ,
  • Wed, Jun 13 2012 10:07 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Importing REELS from Liquid into MC 5.5
    Hi Ian, the audio files should direct import into Media Composer, the M2V file is easiest converted using Sorenson Squeeze, converted to an Avid DNxHd codec that will fast import or ama link into Media Composer.
    Once all these 3 files are brought into Media Composer add a mark in at the start of all and autosync using that mark to get one single clip to work with .
    Tomas
  • Wed, Jun 13 2012 11:53 AM In reply to
    • Ian Nicholson
    • Sydney, Australia
    • Posts 65
    • Points 965
    Thanks Tomas.
    But now that creates an additional problem...
    My original Liquid M2V files play fine in VLC Media Player.
    However, the moment I import them into Sorenson Squeeze 5 for conversion, they flip upside down and some info/display text appears in the bottom left corner that gets converted and added to the resultant output Avid file! WTF??!!!
    I'm outputting a .MOV file in HDxDN 120 format (1080p25).
    VLC plays the new file upside down with the text!
    Any ideas anyone?!!?!
  • Wed, Jun 13 2012 12:15 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    I have seen that a couple of times in the past, this is usually caused my foreign codecs, Nero was one of the apps that caused mpeg 2 codec problems , there might also be other apps that causes this.
    Also installed games can cause this problem .
    Tomas
  • Wed, Jun 13 2012 12:24 PM In reply to
    • Posts 10,089
    • Points 216,615
    Ian Nicholson:
    One source of this problem can be FFDShow.
    Check to see if you have that installed.
    Regards,
    Douglas
  • Wed, Jun 13 2012 12:26 PM In reply to
    • Posts 10,089
    • Points 216,615
    Maybe I should add that FFDshow is normally installed in the background by other applications.
    So you do not have to have actually installed it on purpose.
    Take a look at your "Programme/ Uninstall" list from your Control Panel
    Regards,
    Douglas
  • Wed, Jun 13 2012 12:54 PM In reply to
    • Ian Nicholson
    • Sydney, Australia
    • Posts 65
    • Points 965
    Douglas! You Genius!
    Sure enough, I have FFDShow popping up in my system tray, and for some obscure reason, flip and OSD were checked! How bizarre! A quick unchecking and now Sorenson is behaving itself! Thanks!!
    While you're on...
    Can you recommend the best settings for me to take these HDV M2V files into MC 5.5?
    Best regards,
    Ian
  • Wed, Jun 13 2012 1:02 PM In reply to
    • Posts 10,089
    • Points 216,615
    Ian Nicholson:
    Embarrassed
    Ian Nicholson:
    I think that Tomas is the man for that, Ian.
    I pulled down the blinds on Liquid many many moons ago and, with my short memory span, have forgotten anything I ever knew about it.
    Regards,
    Douglas
  • Wed, Jun 13 2012 1:32 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    A movie says more than 1000 words, just remember that you are on Pal and not Ntsc
    http://community.avid.com/forums/p/84370/477561.aspx#477561
    Tomas
  • Thu, Jun 14 2012 11:10 AM In reply to
    • Ian Nicholson
    • Sydney, Australia
    • Posts 65
    • Points 965
    Thanks Tomas!
    VERY Helpful!
    All the best,
    Ian
  • Thu, Jun 14 2012 11:19 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Nice that you liked it Ian, happy editing
    Tomas
