Latest post Tue, Feb 28 2012 3:54 PM by George Angeludis. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Feb 27 2012 12:58 PM
    • santiagoj
    • Joined on Mon, Oct 18 2010
    • Posts 7
    • Points 95
    Real multi-core please
    When I export, import, make render etc... Avid 6 on a Mac only use ONE core, and no more than 2Gb RAM at most. The Mac Pro has 12core and 24Gb of RAM and does the work as far as a PC with low specification. That's crazy.
    I think nowadays it's necesary real multicore process; multi-render sequences (render more than one sequence at a time); and a render/export queue. If all of these can do in background would be great.
    I know there are different software like Sorenson, but I think it's better if MC can do it alone. Now MC can export several sequences at a time, but all of them must have the same settings. A render queue like After Effects would be great; because sometime I need to do differents compression formats for the same sequence.
  • Mon, Feb 27 2012 1:06 PM In reply to
    Re: Real multi-core please
    It's been asked for before (I know I asked) hopes are it will be implemented in the future.
  • Mon, Feb 27 2012 1:37 PM In reply to
    • santiagoj
    • Posts 7
    • Points 95
    I hope to be alive by then Big Smile
  • Mon, Feb 27 2012 2:56 PM In reply to
    One of the issues with Importing and Exporting is it runs through the Quicktime Engine, which is only single core aware.
    for maximum effectivness, please put the same feature request up on Apple's site.
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Mon, Feb 27 2012 3:06 PM In reply to
    FunkyDragon:
    But Quicktime will be killed off soon so it makes far more sense to find a better solution.
    Even Quicktime X as shipped on new Macs shows how it's slowly being eroded...
    Quicktime has no 64bit version and likely never will so it's future value is low..
  • Mon, Feb 27 2012 4:48 PM In reply to
    Sorry but at the PC side I can see all cores of my 2600K running up at full speed when
    for example are rendering Looks.
    So it depends on other things too.
    Even at the QT export all cores are working.
    Lower but they are working.
    The same on my laptop's i5.
    MC 6.0.1 USES ALL CORES.
    Desktop PC
    3 Heads Digital Films
  • Tue, Feb 28 2012 8:30 AM In reply to
    • santiagoj
    • Posts 7
    • Points 95
    Ok I'll try 6.0.1 on mac as soon as possible, then I report here the results.
    It's great see multicore. Now, a render queue will be awesome; don't you think so?
  • Tue, Feb 28 2012 1:52 PM In reply to
    Of course but MC6 is a big step ahead as far as previous MC@32bits.
    It will go better as Avid didn't make this change for nothing.
    Desktop PC
  • Tue, Feb 28 2012 3:38 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,159
    • Points 13,950
    George Angeludis:
    MC 6 uses a varying number of cores depending on what it is doing.
    Obviously at certain moments it is single-threaded, while for other tasks the load is better spread.
    I'm observing my Windows task manager quite often as well (and the better Resource Monitor also) Wink
    MC 2018.9 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (10.11.2.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32... [view my complete system specs]
  • Tue, Feb 28 2012 3:54 PM In reply to
    Benoit,
    I have never seen MC6 (as I am observing it too) to load only one core.
    Not on my systems at least.
    I am monitoring it mostly with CoreTemp
    Desktop PC
