Latest post Mon, Jan 2 2012 8:03 PM by AndrewAction. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Jan 1 2012 6:02 PM
    Graphics Without BCC Pan And Zoom
    Does anyone know the best way to work with graphics in MC6?
    I have a 1280 x 960 graphic of a vortex which I intend to slowly rotate.  I zoom into the graphic so as I rotate the edges are not seen and the viewer is immersed, so to speak.  With BCC Pan and Zoom I was able to do it and the resolution quality remained high.  With MC6 there is no BCC Pan and Zoom so where to go?  Avid Pan and Zoom does not have rotating capabilities.  The Avid 3D Warp works but it loses resolution as you zoom in.  Trying it in AvidFX also worked but again, I lose resolution.
     Boy, do I miss Avid Liquid when I work with graphics.
    AMD Phenom II 1090T Six-Core processor, 12GB DDR3 RAM, ATI Radeon HD 5770 video card with 1 GB memory, HDMI, onboard RealTek HD audio ports, analog and... [view my complete system specs]
  • Sun, Jan 1 2012 6:15 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Graphics Without BCC Pan And Zoom
    When it comes to manipulating images, there are very few things that Avid Fx cannot do, you might want to take one more look at possible settings and adjustments.
    About BCC 8 it´s available from Boris, the update price still seems to be 295 dollars although it was said to be 500 dollars after the weekend, if you are fast and lucky you might be able to still buy it for the old price.
    Tomas
  • Sun, Jan 1 2012 7:03 PM In reply to
    Thanks for your reply.  So it seems AvidFX is my answer for Ken Burns type graphic manipulation.  I did see some settings I had not before.  The record moitor of MC6 shows all maniplated graphics with poor resolution so it is frustrating to work with.
  • Sun, Jan 1 2012 7:54 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,620
    • Points 60,370
    Did you set the record monitor to best quality (green)?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Jan 1 2012 9:06 PM In reply to
    • Posts 10,089
    • Points 216,625
    chappyptcruiser:
    With MC6 you get AvidFX6 in the bundle.
    In AvidFX 6 there is the BCC Pan and Zoom filter. The same version as in BCC8.
    Regards,
    Douglas
  • Mon, Jan 2 2012 7:05 PM In reply to
    Here is what I've done and found since your replies...
    Once in AvidFX from MC6 I see Scaling, Panning and Rotating as default capabilities.  I replace the current image with the original (large file to zoom).  Now I can do all the things I need to do with graphics without losing quality.
    Correct?
    But if I actually go to Filters and choose the BCC Pan Zoom effect I don't see Scaling.  Geez! Doug, do you have a tutorial for this yet?  Regardless, for now I can get by with the AvidFX default capabilities.
    I don't know what I'd do without you people and this forum.  Thanks again and Happy New Year!
  • Mon, Jan 2 2012 8:03 PM In reply to
    In Avid FX with BCC Pan and Zoom Filter and the Track selected (not the Face) select the Transform tab at the top and you will have as many options as you want
