Latest post Tue, Jul 10 2012 4:37 PM by mjolnarn. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • Sun, Dec 11 2011 5:02 AM
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 3,990
    DNxHD not an option with Squeeze 8
    I for one will not be upgrading to Squeeze 8.
    Not since version 5.1 have I been able to Fast Import DNxHD material for 1080p 23.976 projects encoded with Squeeze. [http://community.avid.com/forums/p/86042/487186.aspx#487186]
    Thought I would try with the included version 7 but had the same experience as before.
    So I downloaded and installed the verion 8 trial.  This is a 30-day trial of the same Full Professional version that we can have for a $99 upgrade fee.
    Now when I try to recreate my DNxHD preset (.mov), DNxHD in not even shown as an option!!!
    All the other Avid options are present, but not DNxHD.
    This is a show stopper for me.
    Thanks, but NO THANKS.  I'll keep my $99 and keep using {almost any other compression utility} because it actually works.
    MC8.6.1, Z420 Xeon E5-2670, 32GB RAM, GeForce GTX 1080, DIGI002, Win 10 Pro 64-bit [view my complete system specs]
    There are 10 kinds of people in the world, those that get binary, and those that don't.
  • Sun, Dec 11 2011 5:18 AM In reply to
    Re: DNxHD not an option with Squeeze 8
    I seem to remember that one of the posts by DaveAvidPM indicated that greater Avid compatibility (Avid codecs?) would be added back into the lite version.
    The Sorenson Website has changed the Lites features from no NLE integration to having Avid integration. Marianna has said there will be more information early next week.
  • Sun, Dec 11 2011 6:46 AM In reply to
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 3,990
    AndrewAction:
    Yea, but this is the Full Professional Version 8 I'm showing that doesn't support DNxHD.  Every previous version at least let you pick DNxHD as a codec choice.
    Just for kicks I compressed a 1080p 23.976 3:07 minute file using Squeeze 7 Lite and Adobe Media Encoder.  (I would have used Squeeze 8 Professional but can't since choosing DNxHD is not possible.) I used the 175X 10bit codec. Here are the results:
    Adobe Media Encoder: compression time - 4:44, Fast Imported into Media Composer in 1:36, looks perfect.
    Sorenson Squeeze 7 Lite: compression time - 6:18, Imported into Media Composer in 3:31, strobes with alternating black frames, look horrible, totally unusable.
    Granted, Squeeze does a decent job going the other way--creating files for the web from MC reference files, but it's totally useless for creating importable media, at least for 1080p 23.976 projects.
    This is just my experience, your mileage may vary.
    Keith
  • Sun, Dec 11 2011 8:20 AM In reply to
    Why would Sorenson block DNX? That is a dumb decision.
  • Sun, Dec 11 2011 8:25 AM In reply to
    Thanks for the info.
    Cagey:
    Out of interest did your 3.3.1 have the fix for DNxHD codec's.
    Anyhow it is looking likely that Squeeze will remain my fourth, or slip to fifth. choice of go to encoders. Wink
  • Sun, Dec 11 2011 9:16 AM In reply to
    • Edsad
    • UK
    • Posts 87
    • Points 1,195
    AndrewAction:
    Cagey:
    Would you recommend TMPGenc Master Works 5 as a good alternative to Squeeze ? - this encoder programme often crops up on this Forum.
    Ed
    Custom Built OS - Windows 7 Prof - MC 5.5 MC 6 Liquid 7.2 Avid Studio - Asus P6X58D-E Mobo - Intel Core i7-930 Processor - 12GB Corsair DDR3 1600Mhz RAM... [view my complete system specs]
    Custom built - Intel Core 2 Duo E6600 - Asus P5W Deluxe mboard - Radeon X1950XTX Graphics - Kingston 2GB Ram - Audigy 2ZS Sound - 3 x WD 500 GB Sata drives - Windows XP Pro
  • Sun, Dec 11 2011 12:00 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,595
    I am not, and never have been, a big fan of Sorenson. This bruhaha with Squeeze 8 pretty much closes any thought I ever had of using it. My standard workflow uses Tmpgenc, Adobe Media Encoder, MpgStreamclip, or Procoder. They all work equally well; and they all accept QTRef files.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Sun, Dec 11 2011 12:14 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,404
    • Points 15,465
    I use TMPG and I am totally satisfied with it. Sorenzon not for me to use the results to create MPG2. Now I again made ​​attempts with version 8 and again did not work. The big problem with interlaced fields. Sorenson I'm only as a backup encryption program that will not open some files in TMPG.
    William
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Sun, Dec 11 2011 2:03 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,623
    • Points 60,385
    After all that discussion with Squeeze 8 lite vs Squeeze 8 one of the obvious uses for Squeeze isn't even supported?
    That's total crap - I just checked on a full version of Squeeze 8 - no go!
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Dec 11 2011 3:13 PM In reply to
    • erik1185
    • USA
    • Posts 1,063
    • Points 13,095
    DNxHD encoding in Squeeze Lite will be added in an upcoming patch.
    Late 2013 MacBook Pro, 2.4 GHz Intel Core i5, 8 GB RAM, Intel Iris 1536 MB Graphics [view my complete system specs]
  • Sun, Dec 11 2011 3:14 PM In reply to
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 3,990
    AndrewAction:
    Sorry, I didn't make that clear.  3:31 was the time of the import, not the version.  I used MC 6 for all these tests.
    Keith
  • Sun, Dec 11 2011 3:32 PM In reply to
    Cagey:
    My mistake no problem.
    Edsad:
    I think so having used it since the original MPEG only TMPGenc version 1a surfaced on the web.
  • Sun, Dec 11 2011 3:38 PM In reply to
    TMPGEnc 5's quality export can't be beaten by anything out there.
    IMHO, it's better not only from Squeeze.
    And it costs only a few dollars/euros.
    Download a trial and judge it.
    Desktop PC
    3 Heads Digital Films
  • Sun, Dec 11 2011 4:23 PM In reply to
    • Edsad
    • UK
    • Posts 87
    • Points 1,195
    George Angeludis:
    Thanks for the advise - I'll give it a try
    Ed
  • Sun, Dec 11 2011 8:03 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,623
    • Points 60,385
    erik1185:
    I don't think you understood my post - DNxHD is NOT available in the FULL Squeeze 8 - it's not just missing from the LITE version - Sorenson has issues!
    Steve
