Latest post Thu, Nov 24 2011 11:20 AM by daapap. 55 replies.
Page 1 of 4 (56 items) 1 2 3 4 Next >
  • Sun, Nov 20 2011 6:11 PM
    • dreid
    • Toronto
    • Posts 227
    • Points 3,070
    MC6 - what are your early impressions?
    I was wondering what the general concensus is regarding the new MC6, specifically, its functionality, stability, and how much improvement there is both in features and 64bit ... anyone who is running MC6 on a windows 7 64 bit machine, is this a "must have" upgrade (in the way that Adobe CS5 with its 64 bit After Effects was a "must have")?
    I have been looking for specific statistics that might compare render times in MC5 with those in MC6 ... for example, going from CS4 to CS5, my RAM previews in After Effects went from 6 seconds to 35 seconds, a considerable advantage due to the new 64 bit capability, and a clear reason to upgrade ...
    Alos, is there any new hardware that comes with MC6, a sucessor to the DX line?
    I am looking to upgrade but would like to collect some early impressions from those of you who have made the plunge; my last upgrade experience (from 4 to 5) was ... well, I think you know where I am going with this ...
    MC 8.5.3, DNxIO w/ 10.5.4, Win 7 Pro 64 bit SP1, Dell 7910, Dual 10 core Xeon 3.10, 128 GB DDR4 RAM, Quadro K5200, 1 TB SSD system drive, 1 TB SSD cache... [view my complete system specs]
    And back to a windowless room full of Avids he goes.
  • Sun, Nov 20 2011 7:43 PM In reply to
    Re: MC6 - what are your early impressions?
    still works the same its just the GUI that has been changed. its also faster for me BUT i found some bugs in it. one CRUCIAL one is when you're not using your keyboard to trim and you're  using the mouse the preview doesnt show what your trimming, its just a black screen. one of the moderators confirmed this bug and another user as well had this. for now im just using the keyboard to do the trimming (which is what i should be doing anyways...)
  • Sun, Nov 20 2011 8:16 PM In reply to
    • Simon Zimmer
    • Joined on Thu, May 20 2010
    • Easton, Maryland - USA
    • Posts 406
    • Points 4,980
    I upgraded to MC6 too. Overall the impression is positive. Though I had some issues with getting the license installed correctly, I am glad I made the move. BCC 8 is a must if you go up to MC6 since it has so many great effects in the package.
    I like the tabs and the performance seems more stable though there are some bugs. Marianna said a patch is in the works which will fix a lot of things (100+) so that should help a lot. I think that is typical for a new release but after a few patches it will be a great upgrade.
    Overall good job Avid! :)
    MC6 Intel Core i7 x980 3.33GHz 12GB RAM Nvidia Quadro FX 3800 3 HD's in RAID 0 (7200rpm) [view my complete system specs]
  • Sun, Nov 20 2011 8:35 PM In reply to
    • hagi
    • Posts 318
    • Points 4,285
    Simon Zimmer:
    What is in BCC 8 which not in FX6
    HP Z800 2.9Ghz(2x) 12GB Ram, Nvidia Quadro FX5800, Camera - HMC150 Media Composer 8.6 [view my complete system specs]
  • Sun, Nov 20 2011 8:46 PM In reply to
    hagi:
    A few things. Douglas had a thread showing the differences.
    For me it is some Plugins are far more efficient to use as BCC 8 (Drop Shadow for soft animateable shadows to any title or imported file with Alpha for instance). Others, even though they are in BCC8, are more efficient being added via Avid FX. (effects not affecting layers below)
  • Sun, Nov 20 2011 8:50 PM In reply to
    • hagi
    • Posts 318
    • Points 4,285
    Yep, Douglas helped me to understand the difference, and thanks for pointing out the efficciency part. My point was more to the use of the statement "BCC 8 is a must"Big Smile
    AndrewAction:
    hagi:
  • Sun, Nov 20 2011 8:57 PM In reply to
    Here it is a MUST. Brought it the first day I could!! Geeked
  • Sun, Nov 20 2011 11:13 PM In reply to
    • TrevorA
    • Posts 1,348
    • Points 15,280
    MC6: Niggles & thoughts...
    Looks like a good port to 64 bit... some nice new features building on some of the strong stuff that came with 4/5/5.5... I am very impressed.... but here's a few first impressions...
    Still can't adjust audio clip gain without stopping timeline (audio loop and automation notwithstanding).
    V Meters look good - but are only available on tracks and not on outputs (Or busses).
    Still no busses.
    Audio Mixer can't be in tabbed window with Bins (or Bins be in with Project/Console etc).
    No option to minimise audio mixer (eg. lose meters so we can fit 16 tracks in  a small window)
    Bins don't open in a tabbed window by default (but workaround is to have different bin layouts for different bin selections i want to open)
    CMD-8 should really select effect palette in Project window nowadays... don't really need a separate window.
    Is there a shortcut to move between tabs in a window? (Shift-CMD-[ or ] are usual for FCP)
    Create new sequence - doesn't always enable name entry on creation, but sometimes does. This has been a new feature for subclips for a few releases too. (e.g. right click and create new sequence - sequence selected but not ready for renaming, Shift-CMD-N - new sequence ready for renaming in bin. Intermittent)
    Accessing different groups in audio mixer (Grp1 / Grp2 etc) can't be assigned to a keyboard shortcut. Ditto for Auto/Clip toggle.
    I'd like to be able to disable 'Live' as a mode - not sure why I'd ever need it.
    'Group' instead of 'Gang' in audio mixer hopefully pointing towards some sort of fader groups in the not too distant future.
    Audio mixer is still 0dBFS scale... be nice to avoid the plug-ins and just be able to change meter type there.
    Assigning Audio Mixer / EQ / Audiosuite / Markers to shortcuts - don't always work as expected. (e.g. might call up audio mixer from project window but will not then go to the others) Workaround is to insert CMD-0 between each press.
    5.1 clips - there seems to be little control over 5.1 clips. The only way to adjust the levels seems to be to subsequence the clip, split to mono, adjust levels as necessary, then recombine as a wav and reimport. Not very conducive to fast or accurate work.
    I do hope there is more work going into the 5.1 workflow here (which is already a *major* improvement). Similarly the track monitoring limit is hopefully being addressed soon too.
    (Sorry that all reads like a big whinge now, which it is not meant to be...)
  • Sun, Nov 20 2011 11:36 PM In reply to
    Re: MC6: Niggles & thoughts...
    To avoid duplication, I am have merged the MC 6 niggles and thoughts thread into the MC 6 What are your first impressions thread.
  • Mon, Nov 21 2011 12:31 AM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,213
    • Points 23,820
    imports avchd through ama very fast with no hitches ...a little sluggish if you let it set like going for a cup of coffee takes a moment to come back to life had same prob with 5.0 with avchd but now it is accross the board all kinds of clips p2 sd and hd not a deal breaker but a nusance shop owners will love it... editors just keep working no breaks
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Mon, Nov 21 2011 4:25 AM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    hehe! Didn't mean to step on any "Avid FX" fans by saying BCC is a must. For "me" it is a must because I find the BCC plugins much quicker and intuitive to use than Avid FX. I have also been using BCC plugins with After Effects for years before I jumped ship from Premire Pro to Avid last year so I guess I am just "used" to BCC by now and consider it a must in the Avid world.
    Maybe it is not a "must" for everyone but for me BCC is a "must" on Avid or any other video editing program because it offers so much and is so EASY to use! I just love it!
    Good night!
    Simon
  • Mon, Nov 21 2011 8:53 AM In reply to
    What I really miss are plugins.
    Desktop
    Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
    Laptop
    MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
    NLE
    DR Studio 18.5|MC 2023.3
    3 Heads Digital Films
  • Mon, Nov 21 2011 9:29 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,415
    For those that have tried, how is MC6 handling projects with AvidFX5.8 FX plugins in the timeline?  Is it seamless, does it promote the timeline or do you have to rebuild the FX?
    MC8.10 Win 7 64 with Dongle, Dual 10 core Xeon, Quadro K4000, Adaptec RAID 5-8x3TB, External TB2 4x3TB, 64G RAM, BM Intensity Pro 4K. NewBlue Titler 6... [view my complete system specs]
    Vote 1 - Dongles.
    UME an old engine, now with 4K, mags and furry dice....
  • Mon, Nov 21 2011 10:57 AM In reply to
    I don't think it will even understand it.
    They are 32bit.
    What's 32bit doesn't exist for MC6.
    Desktop
    Laptop
    NLE
  • Mon, Nov 21 2011 11:10 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    I'm guessing the question about Avid FX 5.8 concerns how MC 6 with Avid FX 6 works (promotes) older projects that used Avid FX effects - apparently it's supposed to work and simply promote the old Avid FX effect to work with the new Avid FX 6, but I haven't tried it yet.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
