Latest post Wed, Jan 29 2014 6:35 PM by Telegram!. 47 replies.
Page 3 of 4 (48 items) < Previous 1 2 3 4 Next >
  • Sat, Dec 22 2012 11:11 PM In reply to
    Re: REQUEST for an option with the Select Left/Right Buttons
    Pat Horridge:
    Isn't that 6.5.2
    It is. Not 6.5.0.2.
  • Sun, Dec 23 2012 8:54 AM In reply to
    • TrevorA
    • Posts 1,081
    • Points 12,305
    Pat Horridge:
    Isn't that 6.5.2
    That's the one (or the two)
  • Mon, Dec 24 2012 2:30 AM In reply to
    • mcdannyj
    • Joined on Sun, Oct 9 2011
    • Posts 24
    • Points 330
    Well hey!
    Delighted and enthused to see a change like this!  I've recently been playing around with Premiere Pro 6.0 just because they out-and-out copied Avid's trim tool functionality (which is really nice, by the way, and Avid editors should know about it...). But if this works as I hope, then this little change once again puts AVID on top as the best straight editing tool on the block, bar none.  Thanks AVID software team!
    2014 Macbook Pro 2.8 GHz Intel Core i7 ● 16 GB RAM ● 27" Cinema Display ● Media Composer 2018.10 (on Mac OS X 10.12.6) [view my complete system specs]
  • Mon, Dec 24 2012 5:44 AM In reply to
    • Nnata
    • Joined on Tue, Jul 13 2010
    • Posts 1,026
    • Points 13,665
    jogotron:
    Sometimes adding an edit is not the solution, such as when you have many layers of audio that overlap.  Adding edits there will cause all kinds of unnecessary issues - especially with layered sound effects that have been precisely timed.
    Yes exactly....more often than not.
  • Mon, Dec 24 2012 5:49 AM In reply to
    • Nnata
    • Posts 1,026
    • Points 13,665
    TrevorA:
    now available in v6.5.0.2
    mcdannyj:
    Exactly.  And to put it on the record for future browsers of this topic... here's a visual:
    Select all to the right of the timeline indicator - all tracks enabled - and you currently get this...
    current select
    And in my suggestion, if you held down the option key, you'd get this instead:
    optional select
    Would love to see this option.  Okay... I'm getting off my soapbox.
    Thanks for reading!
    Big Smile
    Sorry, just to confirm, has this feature actually been added now?
  • Mon, Dec 24 2012 8:35 AM In reply to
    Nnata:
    Yes, in 6.5.2.
    Media Composer 2018.12 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Mon, Dec 24 2012 3:18 PM In reply to
    Check out this thread http://community.avid.com/forums/t/115549.aspx and read page 5 of the ReadMe file attached.
  • Mon, Dec 24 2012 4:24 PM In reply to
    • Nnata
    • Posts 1,026
    • Points 13,665
    Just installed 6.5.2. I applied the alt/option modifier to this option and ...NEK MINNIT....nothing! Can anyone confirm that they have sucesfully executed this opertion in Symphony 6.5.2? I've tested it a few ways with no luck.
  • Mon, Dec 24 2012 4:43 PM In reply to
    • stevecohen
    • Joined on Mon, Jul 3 2006
    • Venice, California
    • Posts 499
    • Points 5,520
    It works in 6.5.2 Media Composer. Select your tracks, park the playhead where you want the selection to start. Hold down option (or alt) and hit Select Right. All clips to the right will be selected, in the active tracks. No black -- not at the playhead or anywhere else -- will be selected.
  • Mon, Dec 24 2012 4:45 PM In reply to
    Nnata:
    I've tested it on Symphony 6.5.2 on a PC and ALT+select left/right selects clips only, leaving filler unselected.  Haven't tried it on a Mac.
    Try with a new user and a new project, Ben, and see if anything changes.
  • Mon, Dec 24 2012 4:55 PM In reply to
    Ben and Carl:
    Symphony 6.5.2 on MacBook Pro 3,1 running 10.7.2. Opt + Select Left or Right does indeed ignore the filler clips. Standard click Select Left or Right includes all filler clips.
  • Mon, Dec 24 2012 5:26 PM In reply to
    Hi all,
    This ALT (OPT) function works indeed as expected using keyboard shotcuts.
    What doesn't work is, adding the ALT/OPT modifier button from the command palette to the keyboard settings. (and the little ALT/OPT point appears on the button shortcut.)
    Engineers  are aware of this 'bug' and working on it.
    Social Media Manager at Avid
    Editor-in-Chief avidblogs.com
    Got a great story to tell for #TimelineTuesday?
    Want to share a Media Composer Tutorial on #TutorialThursday?
    Contact me!
    Twitter: @editorbelga
    Facebook: fb.com/editorbelga
  • Mon, Dec 24 2012 5:52 PM In reply to
    • Nnata
    • Posts 1,026
    • Points 13,665
    Wim Van den Broeck:
    Hi all,
    Ahhh yes that's what threw me, I went straight for the command pallets alt key assignment. Glad the to hear the engineers are onto this...regardless , very happy to have this essential feature now.
  • Mon, Dec 24 2012 6:26 PM In reply to
    • TrevorA
    • Posts 1,081
    • Points 12,305
    Nnata:
    TrevorA:
    mcdannyj:
    current select
    optional select
    Thanks for reading!
    Big Smile
    Well it looks abut different from those grabs in that it doesn't select *any* filler after cursor. Does it thus change relationship between clips as you slide? Haven't got 6.5.2 myself yet.)
  • Wed, Jan 29 2014 3:46 AM In reply to
    Yes, this works!
    Words cannot express how thrilled I was to read that Avid actually put in this feature. A thread with a very happy ending!
    Media Composer 7.0.3 Macbook Pro 2.6 GHz i7, 16GB RAM. SSD Boot drive. OS X 10.9.1 G-tech 8TB Thunderbolt harddrive. [view my complete system specs]
