Latest post Wed, Mar 14 2012 8:44 PM by gailledrat fabien. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Nov 17 2011 7:52 PM
    • addinski
    • Erfurt, Germany
    • Posts 177
    • Points 2,120
    AVID MC6 German Keyboard Layout
    anyone figured out a way to set German or any other keyboard language layout other than US? I tried new settings etc, but keyboard settings are messed up now. Tried to change OSX language settings. No luck. This has never been an issue before. Going back to 5.5. :(
    MAC OS X 10.11.6 AVID MC 2018.3 + Avid Mbox Pro 3 MACBOOKPRO 15" Retina, i7 2.66 GHz Quadcore, 16GB Ram Dell UltraSharp U2711 Sony FS5 & Alpha... [view my complete system specs]
    Honestly I hate editing.
  • Thu, Nov 17 2011 8:00 PM In reply to
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    Re: AVID MC6 German Keyboard Layout
    This is indeed a problem. Some Keyfunctions are unmappable (don´t know if this is an exiting word Smile)
    Maybe one who knows a little more could chime in here…
    On the other hand MC 6 roars like a lion, thank you Avid
    6TB LaCie 2big, QT X, QT 7.6.6, Squeeze 8.5, BCC 8.2 MacBook Pro Retina 15", 2.5Ghz QuadCore i7, OS Mojave 10.14, Avid MC 2018.5, 16GB Ram, AMD Radeon... [view my complete system specs]
  • Sun, Nov 20 2011 1:54 PM In reply to
    • Kaiser
    • Berlin
    • Posts 87
    • Points 1,255
    "Glad", I'm not the only one with this issue; Examples:
    F1-Key launches 'Help' (Standard-PC-Key). I recall this issue more than a decade ago.
    'Slip 10frames right' marks Audio-Track3 ...
    Don't they do international beta-testing? Obviosly not!
    FSD:
    yeah - it roars loud, but maybe it should have stayed a little longer in kittens basket. Premature release - INMHO.
    MC 2018 on MacBookPro 2013 2.6 Intel Core I7, Mojave [view my complete system specs]
  • Mon, Nov 21 2011 9:44 AM In reply to
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    Lift isn´t lift anymore, instead of lifting it now is slipping 1 frame.
    Trim mode opens up the quick transition window...
    Creating new user settings twice, doesn´t help
    ReMapping from the Command Palette won´t do it
    Even the default user setting is messed up.
    and have a look here
    same Problems on the PC side
    http://community.avid.com/forums/p/102785/592651.aspx
  • Wed, Nov 23 2011 3:18 PM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 177
    • Points 2,120
    Oh boy. I did some more testing and found at least a "sort of" workaround, that does the deal for me. In OSX you can show the input source language as a flag on the menu bar. You can switch it there to the US keyboard and so you can at least assign the tools you need to your keyboard settings. I started from scratch with the settings file in the avid utilities folder called XpressKeyboardSettings. So I can at least cut the way I want in Avid using the US keyboard layout and switch back to German, when I quit Avid. Only downside are systemwide shortcuts like command Z, which becomes command Y for us, etc. etc.
    I know it´s not perfect, but might help to get you cutting.
    André.
  • Thu, Dec 15 2011 6:50 AM In reply to
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    addinski:
    So, are there any news about the messed up keyboard settings Huh?
    regards
  • Thu, Dec 15 2011 1:16 PM In reply to
    Avid is aware and is working on a fix.  No news about when the fix will be released.
    (Sorry this info wasn't posted here.  It was posted on the other keyboard threads, but I hadn't seen this one.)
  • Thu, Dec 15 2011 1:17 PM In reply to
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    thanks for updating Carl,
    i´m working with 5.5.3 so far
  • Wed, Jan 4 2012 1:43 PM In reply to
    Oh THANK you  André. !!!!
    3 GHz 8 core Intel Xeon E5 / 32 GB / 10.9.5 / MC8.7.2.44855 / Motu HDX-sdi via PCIe Card / AMD FirePro D300 2048 MB [view my complete system specs]
  • Sun, Feb 5 2012 9:47 PM In reply to
    • kintscher
    • Joined on Sun, Feb 5 2012
    • Posts 1
    • Points 15
    Hi
    I had the same Issue on Windows 7. I changed the Systems layout, so the keyboard layout Windows is using (probably working on OSX too). It is kind of a workaround in the way of "minus times minus is plus", but at least the key positions are right now.
    Hope it works for you too
  • Wed, Mar 14 2012 8:44 PM In reply to
    Hi there, same problem with french keyboard, have to switch to english keyboard in language bar to have my mapped key doing the right function. Obviously ctrl+a (sellect all) becomes ctrl+q (quit application) and so on... very annoying
