Latest post Fri, Nov 18 2011 10:38 AM by StevenPlum. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Nov 17 2011 3:32 PM
    • StevenPlum
    • Joined on Wed, Jan 12 2011
    • Posts 5
    • Points 65
    AMA or Relinking for DSLR footage
    This may of been covered before but I cant find a definitive answer.
    Best Work Flow for DSLR footage when the system isn't fast enough to edit with the Native h.264's.
    For speed I have been ingesting at DNxHD36.  Is there then a way of relinking to the original h.264 files for export or a way of re-transcoding to 185x? (does this actually benefit 4:2:0 8bit rushes anyway?)
    Recently I used AMA then transcoded to DNxHD36 then exported same as source. Compared to the original h.264 files there was definately added noise.
    Also the whole RBG thing, I have been importing at RGB as thats what DSLR's record in.  SHould I be ingesting at 709? and clipping the colour scale 16-235? What would be the benfits if any?  And If i come in at RGB I should export at RGB right?
    Any help with these matters would be appreciated vey much.
    Best
    Regards
    Steven
    AVID MC5 (latest update)
    Xeon QuadCore 6GBRAM z400HP tower
    Filed under: , , ,
  • Thu, Nov 17 2011 3:44 PM In reply to
    • CColton
    • Joined on Sun, Jul 17 2011
    • Posts 218
    • Points 2,730
    Re: AMA or Relinking for DSLR footage
    Right-click on the imported DNxHD 36 files and click Batch Import. That will allow ou to reimport the exact same files in any resolution. For sequences, right-click and Batch Import or Decompose and then batch import the new master clips.
    Freelance producer/editor/videographer, Colton Media Productions
    Specs: Avid Qualified HP EliteBook 8760w |
    MC6.5 | Intel i7-2640M CPU @ 2.8 GHz | 8 GB RAM | NVIDIA Quadra 3000M | Windows 7 Pro | Software-only, I have no Avid hardware. | After Effects CS4 | Nuke 6.3
  • Fri, Nov 18 2011 10:18 AM In reply to
    StevenPlum:
    Link by AMA and then transcode to DNxHD 120(Pal) or 145(NTSC).
    As the friend told you Batch import them to the new resolution (if you stuck tell us to help you).
    I work like that and didn't see any noise (QT Player is the worse case of juding the quality).
    I use 709 but many times I export as RGB (when it's for the web).
    Best
    Regards
    Steven
    Desktop PC
    3 Heads Digital Films
  • Fri, Nov 18 2011 10:37 AM In reply to
    • StevenPlum
    • Posts 5
    • Points 65
    Thanks for your reply. Appreciated.
  • Fri, Nov 18 2011 10:38 AM In reply to
    Hi Steven,
    post back if you got any problems.
    Desktop PC
    • StevenPlum
    • Posts 5
    • Points 65
    Thanks you, I'll try this.  Much appreciated.
