Latest post Sat, Nov 26 2011 9:16 AM by Henk. 48 replies.
Page 1 of 4 (49 items) 1 2 3 4 Next >
  • Thu, Nov 17 2011 1:24 PM
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Startup problems mc6-- please help
    Till now it looks I am the only person with startup problems, have installed from dvd the Avid Editor Suite and after finishing startup the pc again and try to start MC6, but nothing is happening, after a while I see: Avid Technology is not reacting !!
    What I did:
    )Deactivate the licence !!
    Removed MC 5.0.3 and also Avid Studio from my system so I can start with new installs, what I uninstalled:
    Avid Audio Drivers x64 / EDL Manager / Film Scribe / Avid FX / Log Exchange
    Avid MC / Media Log / Avid Studio / Studio Bonus Content / Studio Plugin and License support.
    Still on my dektop are Avid Media Sync Publisher and Manager.
    Do not know what to do now, did everything above also a second time with the same result.
    Do not installed QT 7.7 , still 7.6 on my system.....can that be the problem ?
    Will install it now to see.
    Recom Powerstation black with Recom Pro Engine M850 Power/ Processor Intel Core i7 920,s1366 2,66Mhz QPI/ Memory = 2 x 3 x 2Gb (total 12Gb)/ 2 HD 750Gb... [view my complete system specs]
  • Fri, Nov 18 2011 4:44 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Re: Startup problems mc6
    Bump..
    I am not the only person with this problem, nobody can help ?
    Did go back to an situation with a working 5.0.3 and then installed mc6 with the same result,
  • Fri, Nov 18 2011 8:32 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Re: Startup problems mc6--please help
    Did a system backup and everything is working again as before installing MC6
    Can somebody help me how to install mc 6, I must have make a mistake somewere:
    What do I have to uninstall from my version 5.0.3 ? see also top from this subject.
    On my system is also Liquid 7.2 and Avid Studio.
    After uninstall everything starting with installing QT 7 and nvidia drivers 275.89 ?
    Thanks in advance for your help.
  • Fri, Nov 18 2011 8:43 AM In reply to
    What I did is to complete uninstall everything from Avid Suite.
    Then I deleted all the files to Program Files x86>Avid.
    Everything there is x86 while MC6 is x64 now and will be placed on
    Program Files>(not x86).
    After the installation at Program Files x86 there will be some apps that
    are still x86 and the License Control.
    I can't comment on Liquid or Studio as I don't use them.
    This is how the Program Files (x86) will look like, minus the AVX2_Plugins folder.
    Desktop PC
    3 Heads Digital Films
  • Fri, Nov 18 2011 1:41 PM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Thanks George,
    Did it the same way as you suggeted, but result is the same, MC6 refuses to startup.
    Next thing to do is install w7 on een clean system and then try again
  • Fri, Nov 18 2011 1:53 PM In reply to
    • Simon Zimmer
    • Joined on Thu, May 20 2010
    • Easton, Maryland - USA
    • Posts 406
    • Points 4,980
    I had issues too but called Avid Support and they got it fixed pretty quickly. Call them up and see if they can help.
    Good luck!
    Simon
    MC6 Intel Core i7 x980 3.33GHz 12GB RAM Nvidia Quadro FX 3800 3 HD's in RAID 0 (7200rpm) [view my complete system specs]
  • Fri, Nov 18 2011 2:01 PM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    I am in Holland, so calling will cost and then trying to explane in a (for me) not common language will not help me I am afraid.
  • Fri, Nov 18 2011 2:15 PM In reply to
    If you willing to try a clean install do that.
    I do not know the order Studio etc should be installed after or before MC.
    Use only MC for starters and if it works fine (and you work with it) stay this way.
    Desktop PC
  • Fri, Nov 18 2011 2:19 PM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Doing a clean install now and after installing W7 I wil install QT 7.70.80.34 / NVIDIA V 275.89 and then MC6.0.
    Will cost some time but normally everything must run after all this.
  • Fri, Nov 18 2011 2:40 PM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    Good luck! I am sure a new clean install will solve all the problems.
    Simon
  • Fri, Nov 18 2011 3:03 PM In reply to
    After a clean install the first thing we install is the Chipset drivers.
    Always that. After that everything else.
    If you are not on a Quadro I would choose the newer driver for the VGA.
    Desktop PC
  • Fri, Nov 18 2011 3:20 PM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    oh oh..chipset not installed...did read your reaction to late..mc install is already running.
    I am on a Quadro FX 1800
    Will see what happens
  • Fri, Nov 18 2011 3:25 PM In reply to
    You SHOULD install the chipset driver.
    This routes all the chipsets to the CPU!!!
    Desktop PC
  • Fri, Nov 18 2011 3:28 PM In reply to
    Chipset drivers will have been installed by default. But they maynot be the optimum ones.
    Always best to get the right drivers and install them.
  • Sat, Nov 19 2011 9:13 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Last update:
    Installed everything, also chipset drivers, MC start up now and opens with activating screen, so I filled in everything (not only name  and serial/sys ID but more they like to know ), and now it hangs already 30 min on activating.
    I used the upgrade serial number send by mail by Avid after downloading MC6
    Send a email to Marianna,  do not know what is wrong, do I something wrong, forgot something to do ?
