Latest post Thu, Aug 7 2014 1:03 PM by JeffPierce. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Nov 3 2011 9:46 PM
    • Foster Chen
    • Joined on Wed, Nov 9 2005
    • CA
    • Posts 7
    • Points 105
    VideoRaid ST hard drive swapping
    I have an Avid VideoRaid ST with 5TB storage, and was wondering if it can accept new 2TB hard drives as opposed to the 1TB it currently holds.  i want to swap out all five with 5 new hard drives so as to keep the old data intact.
    Don't want to buy 5 HITACHI Ultrastar 2TB's and find out that they don't work!
    Anybody have experience with this issue?  Thanks!
    Foster
    Media Composer 3 on MAC 8-core Avid 5TB VideoRaid ST Nitris DX [view my complete system specs]
  • Thu, Nov 3 2011 11:58 PM In reply to
    Re: VideoRaid ST hard drive swapping
    Are those Avid drives? The Avid VideoRAID only accept serialized hard-drives. Meaning, it checks the firmware to make sure those drives are "avid drives".
  • Fri, Nov 4 2011 12:21 AM In reply to
    • Foster Chen
    • CA
    • Posts 7
    • Points 105
    They are HITACHI brand drives, Ultrastar 1TB 7200RPM.
    So I'm wanting to replace them with the same brand drives, only now at 2TB each, giving me a 10TB array.
    Don't know if it will work...I've read the User's Guide and it only states 5TB, but that was when 1TB was the highest capacity drive available.  So technically, it should work...but still risky!
  • Fri, Nov 4 2011 12:46 AM In reply to
    Again, it will not work. The drives must be actual Avid VideoRAID branded drives. Even though they are Hitachi drives, Avid uses their own firmware to identify the drives as Avid drives. You can't use just any drive you want.
  • Wed, Nov 6 2013 1:04 PM In reply to
    Dom Q. Silverio:
    Ok 3 years have passed... but I have just confirmed it on a Videoraid ST.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Sun, Jun 15 2014 4:50 PM In reply to
    • mivko
    • Joined on Sun, Aug 4 2013
    • Posts 13
    • Points 125
    On the other hand, we just successfully replaced the original drives of a VideoRaid SR with standard SATA drives. For testing, we had 4 TB WD RED drives. They were only seen as 2 TB drives, but they worked.
    Maybe it depends on the VideoRaid firmware whether any drives can be used or whether they need to be Avid drives?
    Anyway, it is worth trying.
  • Thu, Aug 7 2014 1:03 PM In reply to
    I have 8 open slots in my Videoraid ST and someone from Avid Tech told me I could poulate these with non avid branded drives. I've purchased 8 drives and 8 drive sleds but have not tried installing them yet. From reading the posts above am I goimg to have problems with these drives?
    Also does anyone have a link to the installation guide for the videoraid St? Can't seem to find it.
    Jeff
