Latest post Wed, Nov 2 2011 2:18 PM by BenoitM. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Oct 31 2011 4:14 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,159
    • Points 13,950
    easiest/fastest online/offline workflow with AVCHD
    Somewhat familiar with MC5, but first attempt to "offline to online"...
    My source clips are AVCHD 17 or 24 Mbps, 50i
    I would like to work on and make a "draft" sequence using a low res transcoding of the source clips, then render to a hi-res version (DNxHD120). Questions before I start doing stupid things:
    Is there a basic offline to online workflow tutorial somewhere - I am absolutely new to this way of working ?
    Are there multiple ways to achieve the same result ? Is using AMA to .mov files transcoded by an external program a good or bad way to do it ? If so, how does one relink AMA to the "online" version of the clips once the draft is accepted ?
    Is working on the draft (offline) in SD (DV25 or 3:1), then go to HD (DNxHD120) for online a good idea ?
    The doc I read so far seems to assume some basic understanding of offline/online workflows...not being a pro, I would like a good basic tutorial on this...(not found in Douglas tuts ?)
    MC 2018.9 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (10.11.2.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32... [view my complete system specs]
    Filed under: , , ,
  • Wed, Nov 2 2011 2:18 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,159
    • Points 13,950
    Re: easiest/fastest online/offline workflow with AVCHD
    BenoitM:
    Anyone ?
