Latest post Fri, May 11 2007 2:00 PM by Frankly Avid. 12 replies.
Page 1 of 1 (13 items)
  • Sat, Feb 18 2006 3:29 AM
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    DIO Flamethrower timeout error with RAID 0
    I have read the posts about 1394 cable not being adequate and such – however, my 80GB Maxtor runs (IDE 2 ATA 100) perfectly with the DV out feature, and –to my dismay- the 2 Ultra133 200GB Maxtors (raid 0) always run the flamethrower error. Now, could it be: 1. The Raid 0 ATA 133 speed throughput is too much to handle; or 2. my onboard VIA OHCI drivers are not compliant? Why does my ATA 100 drives with DV out selected run perfectly, but not my raid Drives?
    Thanks!
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
  • Sat, Feb 18 2006 5:55 PM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Re: DIO Flamethrower timeout error with RAID 0
    No one has an answer, huh? Sometimes it plays, but upon pressing the space bar, it glitches then starts to play; however, it continues to glitch until tehe DIO error comes up. Turning off DV out does work, but I would like to use my DV out (no mojo, just Sony GV-D300). It still works when I use the ATA 100 drives, just not teh RAID 0 133 Drives. The ATA drives are in fine conditiona and the read/write speeds are 84-107 mbs, and access times are 9-9.3...
    Sincerely,
    Trying to see if anyone has the same problem.
  • Sat, Feb 18 2006 7:24 PM In reply to
    • xyedit
    • Boston, MA
    • Posts 2,119
    • Points 27,025
    Have you tried these suggestions?
    *I think it might be the VIA chipset, Avid no likey VIA.
    Dell PWS360 P4 2.4GHz 1.5GB RAM 80GB system drive 500GB internal SATA2 media drive >1TB... [view my complete system specs]
    Kenton VanNatten (will edit for money)
  • Sun, Mar 26 2006 10:56 PM In reply to
    • Rezusfilm
    • Posts 19
    • Points 255
    I have the same problem AND I have a VIA Chipset, what do I do?
    see my problem at: http://www.avid.com/exchange/forums/73992/ShowPost.aspx
    Pierre
  • Mon, Mar 27 2006 1:36 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Just buy the ads Pyro 1394 card; you'll be glad that you did....
    lunalobo
  • Mon, Mar 27 2006 4:14 AM In reply to
    Is the motherboard a multi PCI bus motherboard.  If you have the 1394 port and the storage on the same PCI bus that can cause problems.  And yes, it's not worth the couple dollary you might save on a cheep 1394 card, get the Pyro card, it's $25 here http://www.buy.com/retail/product.asp?sku=10370677&loc=101&sp=1.
    MB: Tyan s2895 K8WE CPU: 2x Opteron 254 Memory: 4GB Graphics: Nvidia Quadro FX 3400 Storage: 1x 80GB Hitachi 7K80 System, 8x Hitachi T7K250... [view my complete system specs]
    DavidN
  • Tue, Mar 28 2006 11:49 AM In reply to
    • Rezusfilm
    • Posts 19
    • Points 255
    Sorry,
    I meant I have a VIA SATA chipset. My 1394 card is an old Studio DV plus card with two firewire ports on it. Still think I should buy me a new 1394 card?
    Pierre
  • Tue, Mar 28 2006 1:25 PM In reply to
    Buy the approved card, save the headaches
    XW8200, 2G ram 160G sata system drive, Xpro 4.6, Nvidia FX1300, Pyro PCI 64 FW card, Mojo, 2-300G seagate ext FW drives, 2 - 250G int seagate 7200.8 sata... [view my complete system specs]
    "Life is what happens while you're busy making other plans" - John Lennon
  • Tue, Mar 28 2006 3:24 PM In reply to
    • Quilt
    • Joined on Mon, Dec 19 2005
    • Tewksbury MA
    • Posts 458
    • Points 5,555
    • ! Avid Employee
      Avid Customer Service
    I've seen some strange things throw flamethrower errors among which are from:
    DSR 11 had its input switch set to S-video.
    Corrupt effect in the timeline.
    Incompatible video card driver.
    Added RAM was a different manufacturer from the factory.
  • Tue, Mar 28 2006 9:24 PM In reply to
    • Rezusfilm
    • Posts 19
    • Points 255
    Ok,
    Now we're getting somewhere... first three are not applicable to me, but the third... going to certainly try kicking out 512 extra non-Kingston ddr.
    Thanks for helping,
    will post the result.
    Pierre
  • Tue, Mar 28 2006 10:43 PM In reply to
    let me add a bad scsi card to the dio flamethrower error pool
    dell m70/Pent. M 1.86/2gb ram/nvidia go1400 256mb/60gb 7200rpm internal system drive/60gb 7200rpm internal media storage drive/250gb usb2/1394 external... [view my complete system specs]
  • Sun, Apr 2 2006 10:18 PM In reply to
    • Rezusfilm
    • Posts 19
    • Points 255
    I took out the non-Kingston DDR RAM and nothing changed...
  • Fri, May 11 2007 2:00 PM In reply to
    Check the AUTO EE settings on the deck. Some decks (ex. Sony DSR-1800, Sony HVD-1500) don't seem to play well on the FireWire bus if the AUTO EE Standby is set to PB. Changing it to EE improves the behavior. Changing STOP to EE should help to.
    If you try this, please report your results to this thread.
